Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Leisure Classic 90 slow oven always on
- This topic has 12 replies, 4 voices, and was last updated 4 years, 9 months ago by
Floozy0.
June 19, 2021 at 2:16 pm #99693
Floozy0
ParticipantCould anyone let me know why the plate warmer/tall slow oven always stays on on my Leisure Classic 90? At the moment the element has been disconnected as its the only way to turn it off. The knob is fine and clicks on/off when turned and it heats up properly.
Hope someone can advise on the part required to fix?
June 19, 2021 at 2:25 pm #477431electrofix
Moderatorhas to be a faulty switch but would need complete model no to check how its fed
June 19, 2021 at 2:37 pm #477432Floozy0
ParticipantThanks very much. Checked everywhere (including inside behind oven walls) and only have serial number 5880 001028 Leisure Classic 90 Blanc NG White
June 19, 2021 at 2:58 pm #477433electrofix
Moderatorok found it as its built by rangemaster
if you wanted to turn this element on how would you do it
only ask because i cant find an owners manual to check
June 19, 2021 at 3:19 pm #477434Floozy0
ParticipantIt turned on by the chrome knob at the end named plate warmer/slow oven. Can’t seem to upload a pic…
June 19, 2021 at 3:24 pm #477435electrofix
Moderatorthink that where i would look then. its likely the switch is faulty
as for pics. due to server constraints you need to upload to a picture site then paste a public link
you say the knob clicks on and off, does it do that now the element is not connected
this is still the most likley but its not cheap
this one i think but double check
https://shop.ukwhitegoods.co.uk/p098614-rangemaster-warming-oven-thermostatDave
June 19, 2021 at 3:27 pm #477436Floozy0
ParticipantYes, still clicks ok. Thanks for the link. Will give that part a go…
June 19, 2021 at 6:04 pm #477437electrofix
Moderatorif it still click you would need to double check its faulty. you need to get access to the switch. remove one wire and see if the element still heats up. If no you have probably found it. if yes then i cant think of why it should get a feed
with the price of this switch its too expensive to try it and see
June 20, 2021 at 6:58 am #477438kaibart
ModeratorAs this is a gas appliance and the top needs to be removed to check where the fault is you need to get a gas safe engineer to carry out the repair
June 20, 2021 at 9:10 am #477439tubafan
ParticipantAm I missing something here as the part referenced is the thermostat, not the switch. Or are they one and the same?
June 20, 2021 at 9:36 am #477440electrofix
Moderatortubafan wrote:Am I missing something here as the part referenced is the thermostat, not the switch. Or are they one and the same?
diagram show just a stat and no switch
June 20, 2021 at 9:46 am #477441tubafan
ParticipantLooks like they are one and the same as the stat appears to incorporate the switch. Not a nice price as you say.
🙂June 26, 2021 at 4:18 pm #477442Floozy0
ParticipantThank you for all your responses. The recommended part arrived very quickly and I now have a working slow oven.
