Hi All
A couple of quick questions on this one:
Does any one have a wiring diagram for this one as the spark for the 3 oven/grill sections is not working although they have apparently failed at different times.
What is the way into the back of the clock etc on this one – is it through the top or do I need to get the end cap screws out? I ask because half of the burner screws are jammed solid and the front panel end cap screws are enamel painted over and none want to move to easily so would like to know where it should come apart before I have to use too much brute force and ignorance.
Thank you
Jem
