Leisure CM10FRC (range cooker)
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Leisure CM10FRC (range cooker)
  • #52238
    rocker
    This range cooker has gas hob / electric oven. the small oven has no elec supply,but cant get access to bank of switches, unable to remove facia cover, have removed the screws from underneath facia, but unable to gain access to screws holding the top of facia, can anyone advise. please John
    #311032
    A1TEC
    Re: Leisure CM10FRC (range cooker)
    Dose the top not remove on this style of cooker?
    I have done similar range cookers where you undo the whole spillage top to gain access to burner assembly etc.
    Worth checking as there is always a way to remove it. 😉
    John.
    #311033
    funkyboogy
    leisure use thermal cut-outs at rear of appliance … most are like the ones on beko cookers …. ( built in to wire)
    but there also some with the little round cut-outs as well …
    ally
    #311034
    edthespiv
    to remove top to gain access to facia. remove 2 screws on r/h on top then remove 2 screws from rear holding top on. then slide to right. To remove l/h side remove 4 screw from top then lift off. this will enable you to remove screws to facia
    #311035
    rocker
    thanks gents for reply. John
