Leisure cooker [RCM10CRS] Thermal fuse/cable
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Leisure cooker [RCM10CRS] Thermal fuse/cable
  • #94621
    neon_3SP_glow
    Part required is the Thermal fuse & Cable. It runs from the mains terminal to the timer/clock with the thermal fuse bit clipped into position at the back of the main oven.
    Thermal rating is: T144C
    I can’t find the part required, the closest I can find is this:
    https://connections.connect-distributio … ermal+fuse
    Does anyone know if they are compatible? As in, is the ‘fail temperature’ the same 144C?
    Many thanks.
    #457856
    Lawrence
    Re: Leisure cooker [RCM10CRS] Thermal fuse/cable
    4410101001 is the part no you require
    #457857
    this may help as well
    neon_3SP_glow
    Thanks for your help.
    Much appreciated.
