Leisure Cookmaster 100
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Leisure Cookmaster 100
  • #64389
    csmith
    Hope someone can help. I have a Leisure Cookmaster 100. The main fan oven has stopped working, no light, fan or heat. The red light to say that the oven is on or off doesn’t work and the clock isn’t working either. I’m guessing from reading some other posts that there’s a connection between the clock not working and the oven not working.
    The conventional oven and grill are working fine. No problems with hob either as its gas.
    Can you give me some advice on where to start to get this fixed, is it likely to be the fuse for the clock or something else?
    I look forward to hearing from you.
    C.
    #356908
    Re: Leisure Cookmaster 100
    with the clock failed your oven will not work
    there are 2 choices
    1 replace the clock
    2 short the clock out
    choice 1 is the most expensive and if you do not use the clock it is pointless
    choice 2 requires finding the right wires to join together on the clock to get the oven working. best left to a professional but cost will only be for labour as there is less than a pound in parts
    csmith
    Thats great Dave thanks
    #356910
    Jonah
    Replacing or bypassing the timer won’t resolve this problem, it will be the TOC lead at the rear of the cooker behind the back panel that supplies the timer that is open circuit, it will need replacing
    #356911
    csmith
    Thanks Jonah.
    Could it be a fuse or anything simple like that? And if so, where are these located?
    #356912
    Jonah
    TOC lead is a fuse, if it overheats it will go open circuit and the timer and half of your range cooker will not work, as it’s a dual fuel range cooker with a gas hob I cannot give you any further information other than I would advise you seek a qualified Engineer to complete this repair, sorry.
