Hi, Can anyone give me any help trying to remove a front control panel for the Cookmaster 100 (this is a Leisure brand). It is a dual fuel version. (Gas hob, electric plate warmer and electric ovens).
I got a new control front panel as all the marking for the oven had worn off the old panel.
I have removed the screws from below the panel, but it looks like I might need to remove the gas hob top to get at some top screws? wanted to check this before going too far.
I did see in a Leisure service guide (for a different model) you remove the screws below and ‘slide the panel’ to the right to remove.
Thanks in advance,
