Leisure Cookmaster CM10 BRC – problem with LED clock display
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Leisure Cookmaster CM10 BRC – problem with LED clock display
  • #39516
    AliB
    Hi, I have a duel fuel Leisure Cookmaster CM10 range cooker which is under 2 years old. The bottom half of the LED clock/ timer display has stopped lighting up (the top half is still lit). Can anyone tell me if there is an easy way to fix this? (it is as if there are two light bulbs behind the display and one has blown, but I do not know if this is right and if so, how to access the bulbs). 🙁
    Thanks in anticipation.
    AliB
    #262654
    Re: Leisure Cookmaster CM10 BRC – problem with LED clock dis
    Its possible that the clock has dropped a bit from its holder.
    Otherwise its a new clock assembly.
    Bryan
    #262655
    AliB
    Hi Bryan
    Thanks for your reply and suggestion about the clock. Can you advise me if it is easy to get into the clock to have a look, and also if I need a new clock assembly where I could get this? Many thanks.
    Ali
    #262656
    The hob top and front panel has to come off.
    I cannot find the timer in the on line shop but can you confirm that it is a 6 button clock ass or a 2 / 3 button one.
    Bryan
    #262657
    AliB
    Leisure Cookmaster LEDD display
    Hi, Thanks for your reply. The cooker has 5 buttons underneath the clock/ timer and 3 symbols beside the time on the actual LED clock display. Hope this helps
    Ali
