My Fan oven on model number RCM10CRX recently started to heat up without the fan turning. Sure enough when I replaced the fan, the old motor was burnt out.
However, the fan oven is not working now at all… no heat, fan or light. I suspect the thermal fuse may need replacing, perhaps this tripped out when the old fan didn’t work, although I didn’t notice the heat stopping prior to attempting the repair.
Any suggestions much appreciated!
TS
