Re: Leisure Cuisine Master 100, RCM10CRK Wiring Diagram
Thanks you Dave,
Now re-connected!
However, I’m still struggling with a couple of obscure problems.
The fan oven fan doesn’t work, nor heat, which I suspected was due to a “dead” timer.
I renewed the timer, which remained “dead” and re-checked the wiring to and from it… all ok.
Am I overlooking something?
Plus, both upper and lower left hand hob plates are not working, and both appear fine, and give good insulation readings.
I’m unfamiliar with range ovens, but have checked the switches and wiring to the non working hob plates.
Any help much appreciated!
jonty
