Leisure Cuisine Master RCM10 Regulator
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Leisure Cuisine Master RCM10 Regulator
  • #77558
    stamm
    I have a Leisure Cuisine Master RCM10CRS cooker with a faulty regulator switch on the central dual hob. I have seen posts on here asking how to change the regulators so I assume that they can be obtained from the online store.
    If this is true then how do I order one as I have sent an email via the spares request system 3 days ago & no reply.
    The part I need is an EGO 50.55021.100 which has 2 concentric ellipses on the nameplate unlike the grill switch where the outer ring is not complete also that seems to be a 50.55023.010 . They seem easy enough to change once the top is moved away & the plate under the control plate above the grill is removed. I assume no setup is required?
    Please quote for the EGO 50.55021.100 .
    Regards
    Roy
    #402596
    stamm
    Re: Leisure Cuisine Master RCM10 Regulator
    It seems that the online store do not stock the part so does anyone have any ideas where I can get one from?
    Roy
