Leisure EB10FRX clock
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Leisure EB10FRX clock
  • #67042
    dluck1
    Hi an anyone give me some advice please. I replaced one of the cooker elements last week and it worked fine then today the clock display seems to have no power to it. This is stopping me from using the oven as the clock must be set for it to work. Is there a fuse that I could check first before replacing clock. If so where would it be located it seems as if the cooker is wired directly into a connection in the wall?
    #366060
    Re: Leisure EB10FRX clock
    dluck1 wrote:Is there a fuse that I could check first before replacing clock. If so where would it be located it seems as if the cooker is wired directly into a connection in the wall?
    Sadly there’s no fuseable link on the clock so a new clock/timer unit the only likely cure. And yes they are usually hard-wired (cable) into a 45amp cooker switch box.
    #366061
    washtronics
    the timer can be bypassed, i have done this on lots of rangemasters
