Leisure Gourmet Gas oven will not turn off.
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Leisure Gourmet Gas oven will not turn off.
  • #102504
    mhawthorn
    Helping my daughter, who lives hours away.
    Model GRB6GVK.
    Main, bottom, oven was left on accidentally for a few (4?) hours, and following this she was unable to turn the knob past the 9 setting back round to off. (Sounds odd but I am assured that this is normal operation, to turn past 9 (clockwise) to turn it off, rather than turning down 9,8,7…..2,1 to off.)
    • Knob removed and spindle and knob are in good condition. It’s not that the knob is spinning on the spindle.
    • Spindle will not turn further with pliers. Spindle lubricated, no change.
    • Turned gas off at supply, waited for thermocouple to cool, and gas back on.
    • Suspects gas is still coming from oven burner, so now disconnected from supply at the wall.
    • Checked supply pipe connector with soapy water and all seems well.
    While they find a professional, Gas Safe repair person, does anyone have an idea what has happened? It seems a very dangerous way to fail, that you can’t turn the oven off at the knob.
    Thanks,
    #489223
    well unless you operating it incorrectly then it sounds like the valve has failed
    although rare its a mechanical device so can fail
    you would need a gas safe appliance engineer to inspect and repair
