Hi guys,
anyone know if the control panel removal is as simple as undoing the 4 screws on the underside of the panel (visible when the top oven is opened) and hinging it up and away…or does the electric hob also have to be removed to expose more screws on this model ?
http://leisurecooker.co.uk/Item/GRB6CV
Need to replace the towel rail which appears to be screwed in from the back of the panel….
if the hob has to be removed, is it a simple matter or does it become tricky? (is it sealed in place for example)…
many thanks,
Ant.
