Leisure HJA5100 – Clock fault
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Leisure HJA5100 – Clock fault
  • #84175
    HOK1110
    Wondering if someone can help me with this issue, my Leisure HJA5100 oven has been working fine but the clock display has developed a fault. Only the last 2 digits are displaying making it tricky to get the fan oven to work (i.e. you can’t check what it’s been set to, to over ride it an put it in manual running mode).
    I initially thought it would just be a straight clock replacement but I keep seeing similar / linked faults on the forums with a thermostat issue? Could something else have caused the clock display to fail? Want to be sure I’m going to order the right part!
    #424908
    Re: Leisure HJA5100 – Clock fault
    this is a simple timer so no should not be affected by stst
    but you can also bridge out the clock if you dont want it. the wiring diag show 2 red wires if you join these and disconnect the blue one oven will work with no clock
    part number of timer should be 267100063
    HOK1110
    Thank you Dave, we’ll give the wiring bridge a go as we don’t use the clock. Thank you for confirming the spare part number as well (just in case)
    #424910
    HOK1110
    I may have a stumbled across another issue, having taken the oven apart to bridge the clock wires, I’ve found that my clocks wiring only has 1 red and no blue wires?!?!? Does anyone have the wiring diagram that they could send me?
    #424911
    take a picture of the back of the clock clearly showing wiring
    if i can see the relay i will tell you which ones to short
    dave
    #424912
    HOK1110
    Thank you Dave – Hopefully the picture has loaded below.
    #424913
    2 wires on the right over the white relay ( double brown and white ) join them together
    you need a connector like the one pictured so you dont have to cut the wire and just put them on the same terminal
    also means if you change your mind about the clock all will go back easily
    HOK1110
    Thank you – we’ll give it a go.
