Leisure HJA6100 Diagnostics and any other Info Please
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Leisure HJA6100 Diagnostics and any other Info Please
  • #73993
    Profyaffle
    I Have a customer with this machine and it displays E4. Left unplugged for some time and when he moved home and plugged it back in the Fault E4 was displayed. Any Info, Help would be appreciated. Chris
    #389551
    Re: Leisure HJA6100 Diagnostics and any other Info Please
    You keep posting Tech questions in the General forum….what are you like eh?
    #389552
    don
    Moved :rolls:
    Don
    #389553
    SAMURI
    On top the freezer next to main PCB is normally a sticker with the fault codes.
    The only fault the HJA6100 normally has is the fan motor in the freezer fails.
    The fan also blows the cold air into the fridge.
    If the fan fails the fridge is cold at the bottom ( can freeze food ) and not cold enough at the top.
    Bob
    #389554
    Profyaffle
    Thank you!!! And to you Martin…oops! Please, if you haven’t already, mo be this to the appropriate forum :-s
    #389555
    Criscold
    If you let me have your email I can send you some info in the morning
    Colin
    #389556
    Profyaffle
    Ok, changed Sensor in Fridge, everything doing as it should in diagnostics. However, when attempting to adjust the fill level on the Ice cube tray it won’t let me. ‘Ice off,’ hold selection for 5seconds while in normal operation…..nothing, not a sausage!!! No Parameters displayed, just carries on as if nothing selected…oh dear!! Customer got this new and it’s been locked in his garage for 2 years while his house was being renovated. Epic Fail!!! New board?
