Leisure Naples np10frs not getting hot
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Leisure Naples np10frs not getting hot
  • #72698
    Lazcivic
    Hi everyone
    I have a leisure Naples range oven.
    A few years back we had a problem with it and had someone out to replace the thermal fuse. Cant remember the problem exactly,
    Now, the fan oven turns on, fan goes found and makes right noises but does not get hot. Is this the thermal fuse problem again??
    Any help appreciated thanks
    Lawrence
    Sent from my iPhone using Tapatalk
    #385302
    repman
    Re: Leisure Naples np10frs not getting hot
    Probably the fan element has failed
    jim
    #385303
    Lazcivic
    Fan element?? Oh ok…so nothing to do with the thermal fuse then??
    Is this a easy enough job to do??
    #385304
    repman
    yes should be.power off and remove cover over the fan at the back inside the oven.circular element is around the fan.if the screws are visible you can just remove it then but it may be held in from the rear so oven back case off then.
    ps if you want to order the element a model number will be required
    jim
