Leisure PAS241MB
  • #102717
    Hollytree_Technical
    Hi All
    Does anyone have the service info for this unit please, I have not yet been to see it but the customer states that the fridge has lost temp and the freezer is also begining to lose temp.
    The customer also states that it was fine yesterday but has gone since they had a new smart meter installed – I assume it is just coincidence.
    Are these american style ones as bad as the Beko uprights for gas system problems?
    Thank you
    Jem
    #490165
    sorted
    Hollytree_Technical
    Thank you – much appreciated.
    Jem
    #490167
    Hollytree_Technical
    Having now seen the unit it turns out that there are a couple of large surface mount resistors on the inverter board that had become partially desoldered, having cleaned them up and resoldered them the unit is now working again with a message from the customer to say that it had reached temperature this morning..
    Jem
    #490168
    bad manufacturing then
