Leisure Range cooker 110 (Gas oven)
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Leisure Range cooker 110 (Gas oven)
  • #95634
    rocker
    I purchased a new (clock timer ) for this oven,,I didn’t realise it was an all gas oven..I was unable to remove the electric hotplate….The oven has 4 x gas burners on the LHS and 1 x gas Burner & electric hotplate on the RHS… I need to be able to lift or remove hotplate to gain access the Timer. ( I am not gas qualified just in case any gas needs disconnecting)
    Would like advice from someone who can advise me …..Cheers John
    #460923
    Lawrence
    are you sure its the clock?, if its electric oven and dead its normally the inline TOC
    #460924
    rocker
    Hi Lawrence. Yes the clock works but its so faded can hardy see read it..john
    #460925
    rocker
    It is a gas oven
    #460926
    kaibart
    As you are not gas safe and top needs to come off you probably know site rules
    #460927
    rocker
    Theres no gas to disconnect, when removing the top on this oven
