Leisure Rangemaster 110
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Leisure Rangemaster 110
  • #9488
    Hello
    The cooker is 5 years old, the main oven does not seen to be getting very hot and the fan in the oven has an intermittent fault. Any ideas? 🙁
    #134255
    Hi Rupert,
    IF the fan oven isn’t heating then it’s almost certainly the fan element that’s failed which is an easy repair. If the fan motor at the back is cutting out then it’ll need replaced no doubt and, very probably, why the fan element failed in the first place.
    Dave should be able to supply either part if required.
    Hope that helps.
    Has anyone had a glass cover on a Rangemaster 110 shatter for no reason at all?
    #134257
    Re: Leisure Rangemaster 110
    The normal reason for this is that the door has been closed heavily whilst hot or that it may have had a knock which has weakened it.
    Bryan
