Leisure rangemaster 110
  • #15717
    SWERV
    Hi, has anyone changed the grill switch on one of these? if so any pointers on how to access it. 😕
    Merv
    #166102
    Re: Leisure rangemaster 110
    dual fuel or all electric? either way, the hob splits in 2, the two angled screws in the middle of the hob is the key.
    #166103
    SWERV
    Thanks, it’s dual fuel, 4 burners to the left and an electric griddle and large burner on the right.The grill switch is on the far right hand side.
    Merv
    #166104
    gegsy
    Hi swerv
    The grill switch will be a different one and should come with a mod diagram as the numbers will be different.
    gegsy
    Just to add as Eastimark said splits in 2. there are screws at rear also. L/H lifts clean off after screws removed (disconnect ignitors) and the R/H slides to the right and off again with strategic screws removed.
    SWERV
    Thanks for the advice.
    Merv
