leisure rangemaster 110
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts leisure rangemaster 110
  • #20116
    cornwell40
    Anyone have the grill regulator part number for this range. Front right hand side.
    Cheers
    Tony C
    #185902
    Re: leisure rangemaster 110
    A098256 usualy does those.
    #185903
    bobokines
    Same appliance, does anyone know if the solid hotplates are special in any way or can I fit generic ones?
    Also, any idea how to get the hotplate top off? It is covered in grease and I can’t see any fixing screws at the front.
    Any help will be much appreciated
    Bob
    #185904
    Kirk
    The hotplates you can use pattern, the hob comes off easly undo the 4 screws that hold the rear trim on some are difficult to see if you are old and decrepid like me, then it slides forward and you can lift it up.
    Kirk
    #185905
    There are also 2 screws slap bang in the centre of the hob where the 2 halves of the hob join.
    #185906
    bobokines
    Thanks boys.
    I can’t believe the state some people let their cookers get into!
    It’s only two years old and it is absolutely filthy! 1/4 inch of grease around the rear trim. All of the hotplates have corrodeded. One has split in half!
    I’m going to quote as high as I think I can get away with and hope she goes elsewhere.
    Thanks again for your help
    Bob
