Leisure rangemaster 110
  • #31431
    timjam
    Hi , Does anyone have the configuration from the original diamond h to the to the ego type hotpate switch on this please ?
    Regards Tim
    #231162
    maltheviking
    Re: Leisure rangemaster 110
    Why are you fitting an EGO, replacement switches usually come as DH 😕
    #231163
    timjam
    D.H are obsolute. connections sent ego one.
    tim.
    #231164
    timjam
    Obsolete!!! the original one is a 40er102c1
    #231165
    maltheviking
    Hi Timjam
    DH 40 series is the same as the 41 series but does not have the signal contacts (4 to P2) If you have fitted any of the Hotpoint 41er’s they come a with a convertion sheet, EGO to DH they are wire for wire except for terms 4 which is then connected to 4a
    You should be able to fit the EGO wire for wire + swop 4a to 4 (but check which EGO you have been given)
    Go on to http://WWW.diamond-h.com and http://WWW.egoproducts.com for the details.
    Hope this helps, one of these days I will do a complete cross reference for all the regulators 🙂
    Mal
    #231166
    timjam
    cheers ! the EGO they have sent is a 50 57071 010. Iam sure that the dh one had a double term on 4a, so i will need to put them both on to 4 then .
    #231167
    I have got the conversion sheet, will fax it you if you pm me your number. You do need to fit a link IIRC.
    #231168
    timjam
    no fax , can you e-mail it please ? tim.james@tesco.net. thanks
    #231169
    RocketMan
    I know this is an old thread but the same problem. Old 40er102c1 to Ego 50 57071 010. It’s not here, I’ve looked. Thanks in advance..
    #231170
    RocketMan
    RocketMan wrote:I know this is an old thread but the same problem. Old 40er102c1 to Ego 50 57071 010. It’s not here, I’ve looked. Anyone got the conversion sheet please? Thanks in advance..
    #231171
    RocketMan
    For future searches, this one sorted with help from Rangemaster tech support:
    Line P1
    Red+Yellow 2
    Main neutral (2 wires) P2
    Remaining single neutral 4
    This is for an early version, serial <100999 but may be ok for later versions. Hope this helps someone in the future 🙂
