Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Leisure Rangemaster 110 Dual Fuel – grill element faulty
- This topic has 16 replies, 7 voices, and was last updated 18 years, 11 months ago by
JennyV.
May 12, 2007 at 12:29 pm #27307
JennyV
ParticipantThe right hand side of the grill has stopped working. Can this element be purchased separately?
My husband can move cooker out easily as he does for cleaning etc. and always take care with the gas connection. Is replacing the element straight-forward for a very competent DIYer?Anyone have any idea how much this would cost to have an engineer to replace? (Sorry if it’s against the rules to ask)
Thanks in advance. I love this site. Just wish I wasn’t slowly working my way over the months through all the forums 🙁
Jenny
May 12, 2007 at 5:31 pm #213472Penguin45
ParticipantRe: Leisure Rangemaster 110 Dual Fuel – grill element fault
Grill elements are available separately, spares@ukwhitegoods.co.uk will be able to supply one promptly enough, but they will need the serial number. This is usually found in the warming drawer.
If you choose to have the work done by an engineer, they will charge you for an hours work – rates vary widely across the country, so you should discuss that when making the appointment. Use the link below for a UKW engineer in your area.
Power off if you are going to do this yourself.
Penguin45.May 14, 2007 at 11:39 am #213473JennyV
Thanks Penguin45
May 14, 2007 at 12:23 pm #213474gegsy
Personally, I would replace the two together as if one has gone there is a good chance the other will follow shortly.Plus there will be a significant difference in heat strength between the old and new element due to age.
Greg 🙂
May 14, 2007 at 12:25 pm #213475kwatt
KeymasterRe: Leisure Rangemaster 110 Dual Fuel – grill element fault
Hi Jenny,
The grill element for this should be this one
From memory they are a stock item so only a couple of days lead time.
May 14, 2007 at 1:42 pm #213476JennyV
Thanks Greg and K,
How easy a job is it to replace the grill elements? Where would you start?
Thanks, Jenny
May 14, 2007 at 4:50 pm #213477gegsy
Start by isolting supply to range 😀 :plug: then remove pozi screw in centre of each element in turn. Take your time and do one at a time; make sure you dont lose the wires as you pull element out and they are a fiddle locating main body in holders in roof but perserverence will out 😀Greg
May 14, 2007 at 5:34 pm #213478JennyV
Thanks Greg – you’re a star!
May 19, 2007 at 3:38 pm #213479JennyV
Just to say that two grill elements have been delivered and now fitted by my husband and all working beautifully!
Thanks to everyone for all their help – enjoy these:
JennyMay 19, 2007 at 5:03 pm #213480gegsy
mmmmmmm bagsy caramels 😆
May 19, 2007 at 5:13 pm #213481Penguin45
Orange creme for me, please.
:p45:
May 19, 2007 at 7:58 pm #213482admin
Ive still got most of my teeth so I baggies the toffee’s..
Bryan
May 20, 2007 at 9:04 am #213483helo_75
Participantdo penguins eat chocolate?
May 20, 2007 at 9:08 am #213484gegsy
Participanthelo_75 wrote:do penguins eat chocolate?
Cannibalism :rotl:
May 20, 2007 at 10:04 am #213485Penguin45
Baddum, tish……..
:rolls:
:p45:
