Leisure Rangemaster 110 Gas, both ovens failed
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Leisure Rangemaster 110 Gas, both ovens failed
  • #58611
    Seamy
    Customer tells me that their Rangemaster 110 LPG range has failed, both ovens only light on low flame, (they failed at different times). I’m thinking its a solenoid problem, customer says they had repairs done a year ago & it cost £250 for a FFD part. Thinking if both have gone its likely to be BER.
    Any help appreciated
    #335087
    Re: Leisure Rangemaster 110 Gas, both ovens failed
    you could check to see if the flame sensors have moved or gas burner blocked under sensor
    apart from that sounds like a ffd fault
    A1TEC
    Check out Kitchen Economy, f.f.d listed @ £69.00 8)
    John.
    #335089
    gandh1
    might be ber any way as went looking for some ffds for one of these LPGs last week and parts for rm models when they were owned by leisure are now starting to become obsolete on connect.
    if this is the case best bet is to speak to r/m direct for an alternative part no
