leisure rangemaster 55
Home Forums Public Support Forums Help And Support Cooker And Oven Forum leisure rangemaster 55
  • #8692
    mariellen
    Please help oven flame not getting high seems like gas not kicking in high when you turn the knob up any advice would be appreciated. 🙁 🙁
    #130039
    Re: leisure rangemaster 55
    Almost certainly a thermocouple fault not allowing the thermostat to operate correctly. You MUST get a CORGI qualified engineer to deal with this – check Directories or Repairs at for a suitable UKW engineer in your area. If no joy, please post your post code in the thread and we’ll see what we can find for you.
    mariellen
    Thanks for your responce will locate qualified please could you tell me what that is a thermocouple out of interest and would it be a expensive fault.As is at least 10 years old. 😕
    #130041
    Thermocouple is a device which is connected to the thermostat and the burner. When heated (usually a few seconds) it will hold the thermostat in an “open” or “operating” position. If it fails, the thermostat will not operate (ie no flame) or partial flame if failing. It is an essential safety device.
    mariellen
    THANKS for that information i am interested in how things operate,i will be contacting someone to rectify this.My area is lu3 1ax. 🙂
    #130043
    Marielle
    We cover your area give us a call on 07961365484
    bryan :wave:
    #130044
    Iv’e got exactly the same problem as the person above I have identified a stockist of the thermostats there are two types though the
    GTS1344 & GTS1377 I am not sure which one is on my cooker???
    My post code is M40 1NN any engineers do this area If so how much will it cost to replace barring in mind i’m strapped for cash thats why I need to replace the stat rather than buy a new cooker.
    Thanks in advance
    #130045
    Ps i’m assuming the thermocouple would come as part of the thermostat ❓ i.e the part number above are thous of the thermostat? If not can someone post up a picture so I know what I need to pick up.
    #130046
    Dave_Conway
    The thermocouple and thermostat are two unrelated parts, you must have a Corgi engineer fit the parts so there’s little point in trying to source them yourself to be honest.
    From the directories for you:
    Haworth Appliance Repair Centre Ltd
    Unit 5 Arkwright Court
    Blackpool & Fylde Industrial Estate
    Blackpool
    Lancashire
    FY4 5DR
    Tel: 01253 76220
    Fax: 01253 764445
    Mobile: 07930 433263
    Email: philip.kendall@harc.uk.net
    #130047
    Thanks! I sort of figured after I posted that they where different.
    Check with the suplier mentioned above they have a number of them so I just need a fitter to replace it. Blackpools a bit far for me I live in Manchester.
    Thanks for the advice.
    #130048
    Dave_Conway
    Haworth Appliances cover your area for servicing was the reason for the post bograt 😀
    They will also be able to bring the correct part with them if you give them the symptoms and model details over the phone I would imagine.
    #130049
    Oh right I didn’t realise.
    Thanks Dve will give them a ring.
    #130050
    gegsy
    Also check that the low flame is going completely across the burner thus coming into contact with thermocouple, have had a few blocked burner ports.
    If this is happening its Corgi time !!
