Leisure RCM10CRS rhs conventional oven dead
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Leisure RCM10CRS rhs conventional oven dead
  • #82508
    Simon46
    Got this one when you turn the second from right switch to turn the oven on lights the red light on front panel. The rhs temp control however when rotated does not bring the oven light or elements on. Clock is working. Is there a toc on the conventional oven or is it likely to be selector switch? Want to go armed with spares as its on a piece of worktop higher than floor.
    Regards Simon.
    #420086
    Mo3426
    Re: Leisure RCM10CRS rhs conventional oven dead
    usually toc on these (Beko) on a metal bracket at back of oven could also be selector tho
    #420087
    Mo3426
    assuming that its not the element
    #420088
    Simon46
    Many thanks. Thermal fuse it was. Is there an upgrade to toc auto resetting?
    #420089
    Mo3426
    not aware of one
