leisure rm10crs range cooker
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries leisure rm10crs range cooker
  • #87418
    kwaremont
    the main thermal fuse behind the fan oven has gone the fuse listed is part no 4410101001 is this correct as this fuse switches off both ovens & all the hob rings thanks
    #434795
    Re: leisure rm10crs range cooker
    as far as I can see cutout just supplies live to oven
    kwaremont
    if i short the cut out, out everything comes back on thanks
    #434797
    do you mean the hob as well cause I cannot see the logic of putting the hob through a 15 amp stat
    kwaremont
    the main oven went off at first, then the other oven 30 mins later , then the hob 15 mins later . change thermal fuse & every thing came back on.
