LEISURE RM10FRS – 04 100235 08 – RIGHT SIDE NOT WORKING?????
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries LEISURE RM10FRS – 04 100235 08 – RIGHT SIDE NOT WORKING?????
  • #40558
    Minge
    Hi guys. I have a very strange fault here. The left side (fan oven) and grill works ok, but the right side oven (conventional) and hot plate and even the spark ignition switch has no power… nothing turns on??? The clock is set, the thermal cut-out is ok and no obvious problems with any wiring. Also checked the terminal block but no signs of burning/damage to it?? Any other ideas please?????????????????
    #266814
    Flyman
    Re: LEISURE RM10FRS – 04 100235 08 – RIGHT SIDE NOT WORKING?
    Thermal fuse in the wiring harness under clamp at back of oven.
    #266815
    helo_75
    even though he said it was ok (the clock would be off anyway)
    although there is 2
    one on each oven…..
    #266816
    Flyman
    As you say there are two. One has the oven and clock the other has the oven and ignition unit.
    #266817
    nigegt
    I had one of these just dead yesterday none of it working, found cut out gone changed that and half worked then realised there was one on other side at which point the the customer side “oh yeah that side stopped working ages ago” All good fun
    #266818
    Minge
    Thanks guys but yeah, on the right hand oven the thermal fuse is ok but still dead???? Also would the thermal fuse cause the ignition switch for hobs to not work? Or the warmer plate? Any other ideas?
    :rolls: ❓
    #266819
    roly16
    If Rangemaster make this cooker the user manual might have a schematic diagram
    #266820
    Flyman
    Made by Beko. Two live feeds from the mains terminal block run directly to the thermal fuses on each oven. The feed to the conventional oven also controls the warming plate and the ignition unit.
    Mains terminal block – thermal fuse – P1 on oven selector switch. If oven, plate and ignition unit are not working then fault has to be on that cable. Neutral feed also goes on to the fan oven so if that was faulty then nothing would be working at all.
