hi i need to know if there is an in line thermal fuse running from the term block and timer as timer dead and oven off.if this is a beko made machine it probably will have any part nos please. other numbers cust gave me are rm5cvw
If it is a beko it will have thermal fuse part is flav160100484.
If you go to appliance and remove back to check just find thermal fuse and twist together, then recheck which will let you know if this is the fault but remember this is just a temp fix. Hope this helps.
