Leisure washing machine won’t turn on
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Leisure washing machine won’t turn on
  • #98375
    Sammi Healy
    I have a Leisure RI85421 Washing machine and it started beeping whilst off this morning. I tried to turn it on a bit later but nothing happened. I have tried turning it off at the wall for a few hours but it and plugging it in again and it still isn’t turning on. There hasn’t been a circuit breaker trip. Other appliances work when plugged into the same socket.
    Has anyone else had this experience before?
    Some advice would be much appreciated!
    #472164
    we have had problems with the board power supply on some of these models.
    Sammi Healy
    Ah okay. Do you know if this is something that could be easily fixed?
    #472166
    if it is the same fault any engineer who knows about it can
    if not they will fit a new control board
    cant comment on local enginneers really depends where you are
    Sammi Healy
    Thank you for your help. I will contact a local engineer
    #472168
    you can use our local engineer search
    https://www.ukwhitegoods.co.uk/search/find-an-appliance-engineer
