Leisure Zenith 100 – Think I need a new fuse?
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Leisure Zenith 100 – Think I need a new fuse?
  • #41905
    mshelsbels
    Hi there,
    I’m a newbie to this site, so be gentle! I have a Leisure Zenith 100 Ceramic / Electric oven. The main fan oven has stopped working, as has the clock, but the hob and smaller oven are still ok. I’m thinking I need a new thermal fuse?
    Wondered a), how do I get into the thing to replace it?
    and b), where do I buy fuse from?
    Thanks in advance!
    Hels 😕
    #271702
    It could be the clock that’s faulty, which is more likely but I’d need a full model number to check for you. I don’t think those cookers have a thermal fuse that’d do that.
    mshelsbels
    Re: Leisure Zenith 100 – Think I need a new fuse?
    Hiya…thanks for the reply!
    The model number is ZE10 CRA
    Many thanks,
    Hels
    #271704
    bazza500
    There is a Thermal fuse at the back RHS(looking from the back) about a foot from the floor screwed to the side support bar. Partno. 160100590.
    This will kill the clock and fan oven.
    There is also one on the middle support bar for the conventional oven.
    #271705
    bazza500
    Oops! Meant to say power off if you`re going in. :zap:
    #271706
    Bemused
    bazza500 wrote:There is a Thermal fuse at the back RHS(looking from the back) about a foot from the floor screwed to the side support bar. Partno. 160100590.
    Am I right in thinking that the fuses are the copper U shaped things in the connection panel, if so mine appear fine but I still dont have any power to the clock and the fan oven but all else is working OK. If its not these things then I am stumped as to what you mean as I can see anything else remotely resembling a fuse.
    Hope you can help, missing the fan oven 😉
    #271707
    Bemused
    Having now seen a picture of one of these thermal fuses I recognise them at the back og each of the ovens, this site sells the Beko ones part number 160100534 can I reasonably assume that they are a suitable replacement for the one recomended above?
    #271708
    I don’t know if that one will do as there’s no temperature on it. 😕
    The correct one is HERE
    It’s not a stock item so would take a few days.
    HTH
