I’ve just had a customer with a Leisure Zenith range cooker ring up to tell me that the upper element/grill in her static oven (left hand oven) has blown. The model is 110 DF NG.
Serial No. 5723 007225.
I just can’t quite work out which is which from the photos. If anybody has a diagram that you can identify it from it would really be appreciated..
Re: Leisure Zenith 110 DF NG Static oven grill/upper Element
This unit has 2 cavities on the left hand side, the smaller upper has 2 separate grill elements, the larger lower is a static oven with a dual element… it is actually a Rangemaster.
grill elements are P038435 ( there are 2 of these)
the twin element for the static oven is P026810
There is 1 cavity on the right which is the fan oven.
