LG 1280 FHD bearings replacement
Home Forums Public Support Forums Help And Support Washing Machine Help Forum LG 1280 FHD bearings replacement
  • #24628
    fusil
    Im going to have a go at replacing the bearings on my LG1280FHD washer i have removed the 18 or so bollts from the rear of the drum/motor housing it is now proving a bit stubborn to come apart is there something i should be doing. thanks in anticipation.
    #202714
    Re: bearings replacement
    fusil wrote:Hi Could anybody advise me if the replacement of bearings on a LG 1280 FHD is a drum out job or can this be done from the rear of the machine. ❓
    There is a bearing on the outside (back) of the tank and a bearing and seal inside the tank. Either way, you need to finish up getting to the inside of the drum. Most LGs I’ve seen have a “clamshell” tank, which splits down the middle, so it’s all got to come out.
    Spares@ukwhitegoods.co.uk will be able to supply with the required bearing set.
    Stay safe, power off at all times.
    fusil
    Re: LG 1280 FHD bearings replacement
    Thanks Penguin job completed took tub out and had to persuade certain items to part using the hammer,probaly be doing it again in 18 months if not less.Thanks for advice.
