Re: LG 1460FHD Bearings + fitting?
Bit of bad luck here,the likeley hood here is that if you just change the bearings and seal then you are likeley to have failure again within a year,the best idea is to see you can get a complete drum tank assembly if anyone has still got them in stock close to you,I still hold both the direct and indirect units in stock(yeh i know there no longer available from LG but there are ways and means 😈 .
I can order the bearings and seals if you want normally delivered within 4 days direct from LG.
If you need any further help give me a call on 07961365484.
oh and by the way this might be covered under LG’S 5yr parts warranty depending wgere you purchased it,there again you’ll be charged £80 by connect for which they pay the engineer £40 approx..good way of connect making more money on top of drasticly increasing the cost of LG parts by at least 40{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} in some cases.
bryan
