Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › LG 1460FHD Washer
- This topic has 7 replies, 5 voices, and was last updated 19 years, 6 months ago by
dsw.
October 3, 2006 at 1:31 pm #21365
dsw
ParticipantWhen washing a full load machine ‘stalls’ and display shows ‘LE’. I’ve watched when the problem occurs and I can hear the motor trying to turn the drum but it only manages a slight movement, tries 2-3 times then displays the fault code (in the manual says motor overload).
The machine is six years old and has had a new main pcb module fitted 2 years ago following some excellent advice given via this forum.
I know a washing machine engineer (unfortunately doesn’t work with LG machines!) who suggested over the phone it might be the motor capacitor but I looked for one on the machine and can’t find it. Is this built into the main PCB?
Any advice much appreciated.
Many thanks
October 3, 2006 at 7:35 pm #190605msappliance
ParticipantRe: LG 1460FHD Washer
As far as i can remember lg do not have a capacitor, Appears more to be a motor fault.
October 3, 2006 at 8:46 pm #190606Penguin45
LE is a door lock or associated wiring fault.
Power off, if investigating.
Penguin45.October 4, 2006 at 6:51 am #190607BobHope
Hi all,
LE is a motor related fault, could be motor or pcb, DE is a door fault code,
this appliance does not have a motor capacitor, i sugest you seek an engineer to help with this problem.Bob.
October 5, 2006 at 9:57 am #190608dsw
Thanks for your comments.
Does the fact that the machine works fine on a spin cycle perhaps point to it being a fault with the pcb? Seems odd that the motor would rotate the drum at full speed but not at slow speeds i.e during the wash cycle.
October 5, 2006 at 8:01 pm #190609cab
does the drum turn freely by hand with no restrictions? if so it could be either motor or module, LG fault codes are a bit vague! 😕 if drum is restricted by a foreign object the slow tumble resistance on motor may show this up to the electronics.
cab
October 5, 2006 at 8:45 pm #190610dsw
Just tried rotating the drum by hand and whilst it does seem to rotate quite freely there is a cyclic clicking sound that doesn’t sound as though it’s coming from the motor. Possible foreign object? I don’t suppose there’s any easy way to check without dismantling things?
DSW
October 6, 2006 at 2:18 pm #190611cab
the cyclic click could be the armature on the motor! 😥
cab
