LG American style fridge freezer
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum LG American style fridge freezer
  • #21893
    JasonM
    I have a LG GRB207TUJ fridge freezer and am not 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} happy with the door seals they do not seem that good to me, they keep coming off and need to be checked often to make sure they are still on properly.
    I am also not sure that warm air is getting through into freezer, I do not know how often the compressor should be running.
    Has anyone else had any experience of this model?
    Jason
    #192937
    Re: LG American style fridge freezer
    not had any experience with this particular appliance, but as long as there is good suction on the doors when you open them (there should be at least a little bit of resistance) and also check around the seal with the door closed to make sure the seal is tight to the cabinet.
    If warm air is getting in there, the compressor would have to work harder, but dont worry about how much it comes on and goes off, there is no particular pattern, it all depends on how the appliance is used. (ie how many times you open the door, etc.)
    If there is warm air getting in there, you might notice a build up of ice, or condensation forming inside around air vents and maybe elsewhere.
    If the seals arn’t tight enough, warm them up with a hair dryer and stretch them a little (pull from door towards you, not vertical!)
    #192938
    JasonM
    Thanks for your info.
    I will keep an eye on it.
    JasonM
