LG belt…..recommended one is wrong
Home Forums Public Support Forums Spare Parts Help LG belt…..recommended one is wrong
  • #65068
    kanigit
    Hi all
    Newbie here, never thought I’d be posting on a washing machine forum, but there you go……..
    Issue I’m having is with my LG WM10260T – trying to obtain the right belt is proving to be a nightmare, mainly because we brought the machine with us to South Africa when emigrating in 2007. I can’t get the part here, and have ordered a part from http://www.washerhelp.co.uk ………..but although it was the recommended part it does not fit (part # is 4400FR3116D)
    LG UK have given me 2 alternative part numbers,
    a) MAS42413101 (belt length is too short)
    b) 4400FR3116C
    I’m trying to locate the latter, and to find out what length it is.
    Also hoping to hear from anyone else who’s had the same problem, and what is the correct fix? Driving me nuts, it’s just a silly belt!
    ta
    #359047
    Re: LG belt…..recommended one is wrong
    Whilst I am not sure about LG machines, most belts for modern machines are extremely tight when new. It often leads to people thinking they have the wrong belt when in fact they have underestimated the sheer brute force needed to fit the new belt.
    Are there any numbers or letters on the old belt that would give an indication of size?
    #359048
    BobHope
    the correct part number for that appliance is 4400FR3116B.
    Bob.
    #359049
    kanigit
    Hi – yes numbers on original belt are:
    4PJ 1120
    076L7 1305
    Sheer brute force – hell, this will need hydraulics to get the recommended part on!!
    Belt I was sent is about 112cm diameter – the original (still working – just) is about 116-166.5cm. I can’t get 4cm stretch even with a jimmy bar! :rolls:
    What’s the secret?
    @Bob
    : I think LG told me the 4400FR3116B and …….3116D are the same?
    #359050
    One way is to lash the belt to the main pulley with a stout plastic cable tie, feed the loose belt over the motor pulley and then using aforementioned brute force turn the drum and the main pulley to wind the belt on.
    The numbers on your original belt suggest it was 112cm when new. The 4PL1120 number is possibly the belt size, type and number of ribs. does the new belt have 1120 on it anywhere, if it does then it would appear to be the correct belt.
    What is the problem with your old belt, if it keeps being thrown off then it has stretched ( about 4cm 😉 ).
    #359051
    kanigit
    Thanks for that advice iadom!
    The old belt is still working, doesn’t get thrown off – I was told by the local serviceman here that the sound I hear is a loose belt (it is a squeaky/scratchy sound every time the drum starts to move, especially when I have a fullish load in).
    So luckily machine is still working.
    You asked about number son the belt I was sent:
    5 PJE 1182 and
    9 257 are all I can find.
    I am worried about using the amount of force you recommend – if I do get the belt on, won’t it destroy either the motor or drum bearing under such tension? If it is designed that way (?) I will give your method a go.
    #359052
    5 PJE 1182…curious,
    That is a 5 rib, electrically conductive,1182mm poly vee belt.
    Doesn’t appear to be the correct belt at all. 😕
    I would try and get hold of the belt number that Bob mentions TBH.
    A light dusting of talcuum powder can stop the noise for a short while but it does sound as though your belt is slipping slightly.
    #359053
    kanigit
    Thing is it is a major mission to get a belt ordered in UK, and sent out to me, only to find it is the wrong one.
    LG in SA are worse than useless, so I need to make sure of the right belt…………….I bought the machine in UK, so I contacted LG UK. The first part they recommended was the on ei had alreday received (incorrect) – they then asked for the serial # and came up with 2 other part numbers.
    How difficult can it be just to get a belt with the same numbers? Or is this not how things work?
    really need to get this right before old belt breaks.
    Anyone? 😕
    #359054
    BobHope wrote:the correct part number for that appliance is 4400FR3116B.
    #359055
    kanigit
    Ok, so I enquire about that part and here is the response:
    “Dear Mr. xyz,
    Again, the part number you gave refers to two belts. The first is 5045-1720-3975-0 which is 1182mm and the second is 5045-1782-4665-7 for which we do not have the measurement details. Both products are special order items which means that they have to be ordered in especially from the manufacturers and can therefore take 14-28 working days for delivery from the point of ordering”
    Do I have any option other than to order the 2nd one and hope?
    Couldn’t LG make this a little more complicated, it just bores the hell out of me!!!!!!!!!!!!!!!!!!!
    #359056
    Join the club..LG spares problems :rolls:
    #359057
    kanigit
    oh crap, Life not so Good then ? 👿 👿
