Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › LG Condensor Tumble Dryer TD-C70045E
- This topic has 7 replies, 3 voices, and was last updated 13 years, 8 months ago by
jontymox.
August 6, 2012 at 2:40 pm #70822
jontymox
ParticipantGood afternoon all,
Wondering if anyone can advise on a problem with the above m/c?
When a programme is selected, and started the unit does not work.
The CLEAN FILTER light illuminates, a couple of clicks from the electronic control unit are heard, and the alarm buzzer activates after a few seconds.
The water pump kicks in, but no drum rotation.
The filters and condensor have been cleaned, and are fine.
I have tested the drive motor, and obtained 45.6 Ohms between the Red and Blue wires, with no reading (1.) between the White and Blue wires.
Does this sound like a faulty motor, and if so, would that cause this fault due to not rotating the drum?
Or should I be looking in other areas?
Best wishes,
jonty
August 6, 2012 at 4:20 pm #379071QUICK FIX
ParticipantRe: LG Condensor Tumble Dryer TD-C70045E
checked the motor capacitor very common
August 8, 2012 at 4:58 pm #379072jontymox
Initial diagnosis of suspect motor proved to be correct.
Jon
August 11, 2013 at 6:39 pm #379073colly
jontymox wrote:Initial diagnosis of suspect motor proved to be correct.
Jon
Got the same faultDid you fit the motor ? And get the machine working ?
Kind regards
Colly
August 11, 2013 at 6:43 pm #379074QUICK FIX
very common motor capacitor try that first
August 11, 2013 at 6:49 pm #379075jontymox
Good evening,
Obviously, I cannot rule out a faulty capacitor, although the motor itself was faulty on the m/c I repaired last year.
Best wishes,
jonty
August 11, 2013 at 7:03 pm #379076colly
Cheers
I have fitted a capacitor,which failed to sort it.
Done some research and everybody seems to have the motor even amazon.
I would think it is a common failure.
Will go back tomorrow to do some tests on the motor.
Thanks for your swift reply.
Colly
August 14, 2013 at 7:59 pm #379077colly
ParticipantRe: LG Condensor Tumble Dryer TD-C70045E filter clean error
Hi All
Just to update this post
Went back to this job and metered out the motor.
I found I could only get a resistance reading across the two outer pins rd&bu
I found I could not get a reading across all three of them.
I have since ordered a new motor and fitted it .
The readings for future guidance are as follows
Between blue and white pins 24.5 ohms
Between red and white pins 22.6 ohms
The dryer is now working fine.
Kind regards
Colly
