Re: LG direct drive
I would think it unlikely that the damp conditions would be the cause….I am guesing it has been okay up to now?
If you have changed the motor it is likely to be the power supply board, however I have had one or two of these with a harness fault!
I am not sure on the direct drive models but on the belt drive I found a fracture in the cable right near to where the motor plug connects. It was not visible,but a wiggle of the cable bought up the fault whilst on spin.
The machine assumed there was a tacho fault.
