I have the above washer dryer now displaying:
fault code: FE
Symptoms: drum keeps filling with water, unit it stops displays fault code and then drains, but not fully.
hand book fault description: Water overfills due to the faulty water valve
Action: Close the water tap. Unplug the power plug. Call for service
I’ve looked at the guides on your website and I’m going to test the valve with a multi meter to check its continuity however, has anyone come across this fault before?
Code it be another component.
Machine just out of warranty.
