Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › lg direct drive squealing when trying to spin
- This topic has 7 replies, 3 voices, and was last updated 8 years, 8 months ago by
elwasher.
July 25, 2017 at 4:47 pm #91767
elwasher
ParticipantHi I’ve got and LG washer that when it trys to spin makes a horrible squealing noise ? I have changed the whole drive unit from a machine I know that works but still does the same thing any ideas??
July 25, 2017 at 4:59 pm #449179electrofix
ModeratorRe: lg direct drive squealing when trying to spin
had the pumps make some horrible squealing noises over the years
if not
what did the customer complain of ?
is the drum out of true so catching door seal ( spider failure )
July 25, 2017 at 5:30 pm #449180elwasher
ParticipantRe: lg direct drive squealing when trying to spin
It’s definitely not the pump. When on the spin cycle the drum tries to turn but then make this horrible noise I know you shouldn’t do this but if you turn the drive plate it will suddenly spin ok it just can’t start the spin without help. That’s why I change the coil unit and hall sensor first off the other machine which worked ok as I thought it was the hall sensor with the error code LE
July 25, 2017 at 5:49 pm #449181electrofix
Ah I think I see you description threw me off
what you mean is it makes a noise whenever the drum try to turn whether is on spin or a wash cycle
yes / no ?
July 25, 2017 at 7:27 pm #449182kaibart
Check the rotar assembly the spline could be slipping where the drum sits Kai
July 25, 2017 at 7:52 pm #449183electrofix
had one about a month ago where the spline had gone. was also under 10 year motor warranty so LG paid for the parts and the customer only paid to fit. All I had to do is give the customer an invoice with the part itemised and they paid up no probs
well impressed
July 26, 2017 at 5:55 pm #449184elwasher
Think you may be right although I did change the magnet rota to one with a metal spline not the plastic one on the original but still did the same thing, although I did notice when refitting the spindle moved into the tub and had to pull it back out?
July 26, 2017 at 6:05 pm #449185electrofix
shaft moving forward is normal when the bolt it tight it holds it
you did not answer my previous question
“what you mean is it makes a noise whenever the drum try to turn whether is on spin or a wash cycle
yes / no ?”
