Re: LG Dishwasher Error 1
If it’s E1 in the display it means that ” the water level in the cavity is dropping” according to LG’s website.
We’ve had a few of these, it basically indicates a leak, when you get there it won’t be leaking I doubt. What happens is the two solenoids that control the flow of water between the upper and lower baskets both stay shut causing no water circulation so the heater protection pressure switch never activates, hence the machine thinks it’s empty.
PCB Fault normally, and they’re over £100 I think.
There’s a product recall on these I believe, if you get stuck on it, refer the customer to LG customer services 😉
