LG Dishwasher LD-12AW2
  • #18027
    bayslions
    Gday,
    Just surfed on to this site so hopefully someone can help.
    I have a LG dishwasher, model number LD-12AW2 which is caput. I had given up on it due to the fact LG are not helping me as there is apparently no service guy South of Adelaide in Australia.
    Well the problem is it starts for about a few seconds then just stops, can hear something inside prehaps a pump. LAst time it washed I heard a series of beeps coming from it but never took any notice, then when opened dishwasher it still had water in bottom. I have cleaned all jets and inlet/outlets pipes but still no difference.
    Hope this infomation helps.
    Cheers Troy Fynnaart
    tnf75@yahoo.com.au
    #177443
    Dave_Conway
    Re: LG Dishwasher LD-12AW2
    It sounds as if you have a blockage or the drain pump has failed.
    Check the waste outlet etc, if you decide to look further inside don’t forget to unplug :zap:
    I would have thought most engineers would be able to help though as the water drain parts etc are no different on LG than any other dishwasher to be honest 😉
    #177444
    qas
    Some of these dishwashers were recalled. See the Product Safety link at http://au.lge.com/index.do and compare the serial numbers listed with your own dishwasher
    Normally there will be an error code come up in the display when the dishwasher detects an error. More information would be a big help.
    Steve
    #177445
    bayslions
    Thanks, I will find out serial number and fault code when get home from work.
    Cheers Troy
    #177446
    bayslions
    The serial number is 106KW00879 but that doesnt fit into recall range.
    No fault comes up, but after starting it you can hear a grinding type of noise (possibily pump?) then it cuts out. The timer still remains on.
    I hope that gives you more infomation.
    Troy
    #177447
    qas
    Drain pump runs for around 30 seconds at start of each cycle, so that looks like the most obvious cause (though can’t guarantee that from here)
    I still would have expected an error code though…
    Part number for the pump is 4681EA2002B and would set you back around $60-$70
    Steve
    edit: It might pay to remove the control PCB and check that it looks good and the plastic housing is not deformed. Power off if opening the panel as many live connections there :zap:
    #177448
    bayslions
    thank you again.
