Hope someone can offer some advice-
I have an LG LD-14AT2 dishwasher (out of warranty) that is no longer cleaning on the lower level. I’ve had the lower arm off and checked that its clean and no blockages. The only slight physical fault I can spot is that the ‘little spinner’ on the end of the arm is not rotating as freely as it might (also sounds a tadge gritty when turning by hand but water is flowing through freely).
I’ve set the machine to just lower level wash but I can tell (from numerous door openings) that the whole arm is only rotating slowly and the little spinny bit isn’t turning at all. Could this be a blockage somewhere further into the machine preventing the adequate water pressure needed to spin?? How do I get at the pipe to check it? Its making all the usual noises so Im assuming it’s probably not a motor fault.
Hope someone can help (again – have fixed washing machine and tumble dryer in last 18months with Mr Conways excellent advice!)
Sazzle – Gungho bird with no idea from down under!
