LG Dishwasher LD2060wh – motor
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries LG Dishwasher LD2060wh – motor
  • #66178
    zeberdee
    Customer has this appliance with noisy wash motor.
    Can anyone tell me if this can be changed with the space available between base and tub, or if it’s more involved as with the later Bosch etc machines? Sorry, this is one I’ve not seen before and need to give a price. thanks
    #363373
    QUICK FIX
    Re: LG Dishwasher LD2060wh – motor
    YOU HAve to remove lid and side panel and front panel,you can then put dishwasher on its side and then if your looking down on it remove screws which hold the base on to the cabinet allowing you to prise trhe base away enough for you to remove the motor then refitt be carefull for the float switch not to fall out,have done this on many occasions without total removal of base.
    #363374
    zeberdee
    Thanks for quick response. Cheers!
