LG dishwasher OE error code
  • #69172
    RHrepairs
    Looking at a lg dishwasher at the moment the error code OE is coming up which signifies drain problem however the pump is working fine…when i select any programme the machine would work and other times when i set a programme it would constantly drain (without filling) and OE would come up. Is the a pressure swtich or sumthing else that might be broken?
    #373937
    don
    Re: LG dishwasher OE error code
    Hi Richard
    Moved you to trade tech enquiries 😉
    Don
    #373938
    A1engineer
    Check the pressure tube isn’t split, especially around the pressure switch the right angle causes problems
    #373939
    RHrepairs
    one slight problem cant seem to find the pressure switch unless its integrated somewhere. I can see the motor, element, salt chamber,pump, antileak floatation device. The fill tube goes straight to the chamber on the side of the machine
    #373940
    keithwilliams
    isnt it behind facia on right side?
    #373941
    ELDAR59
    have you checked the aqua stop or anti leak device?
    sometimes the microswitch can be corroded or stuck closed.
    cheers.
    #373942
    keithwilliams
    Ignore my post. Had a thicko moment there as I read it as washer not dishwasher.
