LG dryer TD-C70040E
  • #56671
    ajohnson
    The CLEAN FILTER light is on and the dryer doesn’t start.
    I removed the large cover on the back side, and tried to help the motor by spinning the fan. Now, the dryer starts and the CLEAN FILTER light goes of. When stop and start the same problem occurs..
    Anyone have the same problem? Please help…
    #328372
    bazza500
    Re: LG dryer TD-C70040E
    Probably the motor start capacitor needs replacing. Power off if going in…and it’s not advisable to have power on with panels removed :zap:
    #328373
    ajohnson
    Ok, thanks for reply.
    I did remove the motor, cleaned it and reassembled it. Without load it works fine, with clothes inside it’s the same problem.
    I’ll try and find the parts and repalce it. Any ideas where to find a cheap capacitor?
    Cheers,
    johnson
