LG Dryer – water on heater :TD-C70045E
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries LG Dryer – water on heater :TD-C70045E
  • #90220
    neilsukwg
    This dryer is allowing water into the heater compartment and tripping the rccb
    The condenser is clean and the pump seems to be working normally
    What could be causing this?
    Also the pump is behind and under the motor. Does the motor have to be removed for access to the pump?
    Cheers
    #444084
    whitevanman
    Re: LG Dryer – water on heater :TD-C70045E
    in my experience it does, nice and easy job just use a 90 degree adaptor on the screws for pump lid under drum or you will have to take drum out, had one a while ago where the pump would turn on when powered of from the control panel, the sensor in sump was ok turned out to be the pcb at the top same side as pump/motor.
