LG F/F GRA207
  • #22930
    Steven
    LG F/F GRA207cvba with error ER/CF which mentions in tech manual “failure of BLDC fan at machine room” what does this mean?, When i looked at appliance fan seems to be working, any ideas
    Cheers
    Steven
    #196563
    bigsmokepiker
    Re: LG F/F GRA207
    We had one down here same fault code ERCF
    Refers to fan motor near compressor fault
    LG suggested to change PCB After testing fan motor OK
    They did suggest also it could be in wiring harness from PCB to
    fan motor (Internal Harness)
    In the end this ended up being the case(there are points on micom PCB to Test)
    Being under warranty they exchanged Refrig over
    If it had not been under warranty the only option would have been to run a wiring harness externally from the top of frig down the back to fan motor
