LG F1247 TD washing machine
Home Forums Public Support Forums Help And Support Washing Machine Help Forum LG F1247 TD washing machine
  • #86936
    Mikecall
    HI,
    I have a 5 year old LG F1247TD washing machine. After starting came up with the IE code (After 4 minutes). Have checked all the filters and replaced inlet valve but still have same problem – the water pressure is good. Any ideas as to what the problem may be.
    Thanks in advance.
    Mike
    #433442
    melec
    Re: LG F1247 TD washing machine
    Hi Mike
    this sounds like a water level control issue??
    The appliance thinks it does not have water when I assume that it does ?
    I have had a wierd pressure switch fault on an LG Top Loader in the past
    Not exactly the same as your fault as my issue was no spin but that ended up being the pressure switch so I know they give off funny errors even though filling levels are normal which again I assume are normal in your case?
    Failing this of course its the old control module left ??
    Was the old valve actually faulty? Did you test it? If so what was wrong?solonoid or mechanical??
    #433443
    Mikecall
    Hi Melec
    Thanks for that was wondering if the pressure switch could be the problem. The old inlet valve still appears to be o.k. but changed to prove the problem.Hoses to pressure switch are all clear have checked them.
    #433444
    melec
    to be honest I do not know a way to test that type of pressure switch ( It just has 3 small tags that you plug into right ?)
    I know that you cannot just quickly blow in and listen for the clicks as is digital so it is a case of changing the part and hoping !!
    Also you will need the exact pressure switch. Dont think because you have another from an LG that has same plug orientation that it will necessarily work.They all have different set ups and therefore part numbers just in case you were thinking….
    All depends on the price of it, don’t think they are too expensive ??
    If it has a normal type pressure switch (11,12,13 etc ) them ignore all that but I have never seen LG with them. Make sense ??
    #433445
    Mikecall
    Hi Melec
    Thanks for that
    Have found one for the machine quite cheap, once fitted (Hopefully Tuesday) will let you know.I can’t think of anything else it can be.
    Regards
    Mike
    #433446
    melec
    Yes please let me know
    #433447
    Martin114
    Could also be blockage at bottom of pressure switch hose
